Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
management-api.stdout auth failed
wan__cm
follow  the owt server Installation ,when I start server  "bin/start-all.sh" the server is not  correct。  i found in management-api.stdout show auth failed.
why  be that ?
I user Release-v4.2.1
 node v8.15.0
help  me!!!
sharma__sumit
Hello Team,
I am also facing the same issue. Not able to access the console from my browser, possibly because of this. Please help!
@wan, are you able to access the console and run a demo call?
Sumit
Li_C_Intel
Can you provide the detail error message?
kiziltas__gorkem
Hi there I am facing with the same issue,
cat management-api.stdout
Authentication failed.
2020-05-01 14:18:14.772  - INFO: ManagementServer - Worker 12764 started
2020-05-01 14:18:14.779  - INFO: ManagementServer - Worker 12769 started
2020-05-01 14:18:14.778  - INFO: ManagementServer - Worker 12763 started
2020-05-01 14:18:14.791  - INFO: ManagementServer - Worker 12770 started
here is the output of error is there any solution for this?
