Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
mcu crashing
Stephen_-_
I have been leaving my webcam on overnight connected to my server to test the stability of release 3.0 update 2 on a ubuntu 14.04.1 VPS
It seems to eventually freeze, and need a reboot, when I do "bin/stop-all" it states "no mcu to stop" which makes me think the problem may be in the mcu.
I'm not really sure if I'm reading the logs right but I hope they could provide some answers. I wish at the least there was a way of detecting when a part of the application has failed and maybe automatically reboot rather than just stay crashed. I haven't modified the server at all yet and it's just using the basic example.
Some parts in the logs:
There's a really long 11MB erizo log file and towards the end it says:
2016-03-01 10:53:55.825  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:54:00.828  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:54:05.830  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:54:14.744  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:54:15.831  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:54:20.832  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:54:25.835  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:54:30.836  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:55:20,929  - WARN: WebRtcConnection - Bad source SSRC in RTCP feedback packet: 1165194345
2016-03-01 10:56:35,404  - WARN: WebRtcConnection - Bad source SSRC in RTCP feedback packet: 2228027394
2016-03-01 10:56:35.407  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:56:35.408  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-03-01 10:56:35.410  - INFO: ErizoJSController - Removing muxer /#EuASka3hdxdipU7CAAAH
2016-03-01 10:56:35,424  - DEBUG: mcu.media.SoftVideoCompositor - Configuring layout
2016-03-01 10:56:35,424  - DEBUG: mcu.media.SoftVideoCompositor - configChanged is true
2016-03-01 10:56:35,424  - DEBUG: mcu.Mixer - notifyAsyncEvent - event: UpdateStream
2016-03-01 10:56:35,424  - DEBUG: mcu.WebRTCGateway - closeAll
2016-03-01 10:56:35,424  - INFO: WebRtcConnection - WebRtcConnection Destructor
2016-03-01 10:56:35,425  - INFO: NiceConnection - video - NICE State Changing from 2 to 3 0x54c9ea0
2016-03-01 10:56:35,451  - DEBUG: mcu.media.SoftVideoCompositor - commit customlayout
2016-03-01 10:56:35,451  - DEBUG: mcu.media.SoftVideoCompositor - configChanged sets to false after commitLayout!
2016-03-01 10:56:35.656  - INFO: ErizoJSController - Removing subscribers /#EuASka3hdxdipU7CAAAH
2016-03-01 10:56:35.657  - INFO: ErizoJSController - Removing publisher /#EuASka3hdxdipU7CAAAH
2016-03-01 10:56:35.658  - INFO: ErizoJSController - Publishers: 1
2016-03-01 10:56:35.660  - INFO: ErizoJSController - Removing muxer 56cf4791da728cad1bc2cd28
2016-03-01 10:56:35.661  - INFO: ErizoJSController - Iterating and closing  /#EuASka3hdxdipU7CAAAH { '/#EuASka3hdxdipU7CAAAH': { wrtc: WebRtcConnection {}, resolution: undefined } } { wrtc: WebRtcConnection {}, resolution: undefined }
2016-03-01 10:56:35,678  - DEBUG: mcu.Mixer - closeAll
2016-03-01 10:56:35,679  - INFO: WebRtcConnection - WebRtcConnection Destructor
2016-03-01 10:56:35,679  - INFO: NiceConnection - video - NICE State Changing from 2 to 3 0x49c8740
2016-03-01 10:56:35,857  - DEBUG: mcu.media.VideoMixer - closeAll
2016-03-01 10:56:36,192  - DEBUG: mcu.media.VideoMixer - Closed all media in this Mixer
2016-03-01 10:56:36,212  - DEBUG: mcu.media.BufferManager - BufferManager destroyed
2016-03-01 10:56:36.212  - INFO: ErizoJSController - Removing subscribers 56cf4791da728cad1bc2cd28
2016-03-01 10:56:36.213  - INFO: ErizoJSController - Removing publisher 56cf4791da728cad1bc2cd28
2016-03-01 10:56:36.213  - INFO: ErizoJSController - Publishers: 0
2016-03-01 10:56:36.213  - INFO: ErizoJSController - Removed all publishers. Killing process.
I don't know if that's relevant or not.
In woogeen-mcu.stdout it says towards the end:
2016-03-01 10:55:10.296  - INFO: RoomController - Adding mixer id  56cf4791da728cad1bc2cd28
2016-03-01 10:55:10.397  - INFO: RoomController - Adding mixer id  56cf4791da728cad1bc2cd28
2016-03-01 10:55:10.499  - INFO: RoomController - Adding mixer id  56cf4791da728cad1bc2cd28
2016-03-01 10:55:10.601  - INFO: RoomController - Adding mixer id  56cf4791da728cad1bc2cd28
2016-03-01 10:55:10.705  - INFO: RoomController - Adding mixer id  56cf4791da728cad1bc2cd28
2016-03-01 10:55:10.807  - INFO: RoomController - Adding mixer id  56cf4791da728cad1bc2cd28
2016-03-01 10:55:10.908  - INFO: RoomController - Adding mixer id  56cf4791da728cad1bc2cd28
2016-03-01 10:55:10.909  - DEBUG: RoomController - Answer timeout
2016-03-01 10:55:10.910  - INFO: RoomController - Erizo created
/root/intel/Release-v3.0.1/mcu/erizoController/roomController.js:1
(function (exports, require, module, __filename, __dirname) { "use strict";var logger=require("./../common/logger").logger,erizoController=require("./erizoController"),log=logger.getLogger("RoomController");exports.RoomController=function(e){var i={},o={},r={},n={},t={},l=e.amqper,a=e.agent_id,u=e.id,c=5e3,s=2,d=[],f=function(e){return function(i){if(n)if(i!==!0){if(n.ka_count++,n.ka_count>s){for(var o=n.publishers,r=o.length-1;r>=0;--r)g("unpublish",o);l.callRpc("ErizoAgent_"+a,"deleteErizoJS",,{callback:function(){}}),delete n}}else n.ka_count=0}},v=function(){for(var e in n)l.callRpc("ErizoJS_"+e,"keepAlive",[],{callback:f(e)})};setInterval(v,c);var p=function(e,i){return GLOBAL.config.erizoController.outOfProcessMixer||void 0===e||void 0===r?void l.callRpc("ErizoAgent_"+a,"createErizoJS",[],{callback:function(e){log.debug("Answer",e),"timeout"===e||n||(n={publishers:[],ka_count:0}),i(e),l.callRpc("ErizoJS
TypeError: Cannot read property 'publishers' of undefined
    at /root/intel/Release-v3.0.1/mcu/erizoController/roomController.js:1:1383
    at Object.GLOBAL.config.erizoController.outOfProcessMixer.r.(anonymous function).l.callRpc.callback (/root/intel/Release-v3.0.1/mcu/erizoController/roomController.js:1:933)
    at callbackError (/root/intel/Release-v3.0.1/mcu/common/amqper.js:1:2752)
    at ontimeout [as _onTimeout] (timers.js:195:34)
    at Timer.listOnTimeout (timers.js:92:15)
in woogeen-nuve.stdout it says:
2016-03-01 07:42:32.773  - INFO: Room - apply custom layout templates
2016-03-01 10:54:56.114  - INFO: CloudHandler - ErizoAgent 2  in  104.233.83.134 does not respond. Deleting it.
2016-03-01 10:54:56.118  - INFO: CloudHandler - [CLOUD HANDLER]: Warning! No erizoAgent is available.
2016-03-01 10:55:21.151  - INFO: CloudHandler - ErizoController 1  in  104.233.83.134 does not respond. Deleting it.
2016-03-01 10:55:21.152  - INFO: CloudHandler - [CLOUD HANDLER]: Warning! No erizoController is available.
2016-03-01 10:55:21.152  - INFO: CloudHandler - [CLOUD HANDLER]: Warning! No erizoAgent is available.
2016-03-01 10:56:35.458  - INFO: CloudHandler - I received a keepAlive mess from a removed erizoController
2016-03-01 10:56:36.029  - INFO: CloudHandler - [CLOUD HANDLER]: ErizoController in host  104.233.83.134 does not respond.
Any idea what might be the issue? Is there an easy way of being notified when this happens so I can at least reboot it? I'm worried this could happen when I'm not there and then it will be unusable.
Sergey_P_1
We have the same problem with crashing MCU server and reboot it every day.
Chunbo_H_Intel1
Hi guys,
Thanks for the feedback. Our engineering team is now working on the solution. Thanks!
Bryan_A_
Hello !
Let these settings, and as the number of rooms and the number of clients:
erizoAgent.maxProcesses
erizoAgent.prerunProcesses
2 weeks ago, I had the same problem.
And now, I seem to have found a solution:
I increased the value erizoAgent.maxProcesses (rooms * 2)
and erizoAgent.prerunProcesses (rooms + 2)
Chunbo_H_Intel1
Thanks for the sharing!
We've identified the issue of "TypeError: Cannot read property 'publishers' of undefined
    at Timer.listOnTimeout (timers.js:92:15)".
And we had some fix against it in the coming release!
Stay tuned!
software__revamp
If help needed, please contact me softwarevamp@gmail.com.
