Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1145 Discussions
no voice when connect to server with rtsp input
Peng_M_
Version:2.8.1 Browser:Chrome 45
When I visit http://xxxx:3001?url=rtsp://xxxxxx the browser only output video stream and no audio stream outputing.
I use VLC to load rtsp stream and everything is ok.
I didn't modify the configuration file except the config.erizo.openh264Enabled=true.
Could you please help me find some possible reason?
Thanks a lot!!
Peng_M_
The audio encoder is MPEG AAC Audio (mp4a). Does it be supported?
Chunbo_H_Intel1
Sorry, the AAC is not supported in this feature yet.
Could you change the audio encoder to G711 or OPUS, and have another try?
Peng_M_
The audio encoder can not be changed.Maybe I can create a new stream for audio siginal.
Thank you all the same!!
Chunbo_H_Intel1
Good. By the way, could you tell me the RTSP camera model if you used any?
Peng_M_
I don't clear its model but I know it can not catch the audio siginal.It is mixed some microphones with some cameras to a RTSP stream.
Chunbo_H_Intel1
So it sounds like this is a RTSP SERVER that will combine audio data (multiple inputs?) and video data (multiple inputs?) into ONE RTSP stream. Is it correct as above?
You information will definitely help us improve. Thanks!
Peng_M_
Yes,you are right.I used these devices in a classroom.
Chunbo_H_Intel1
Thanks for the information.
So my understanding is that you want to bridge your RSTP server output to our WebRTC solution?
Chunbo_H_Intel1
Also, could you provide the video and audio codecs your RTSP server supports?
Thanks!
Peng_M_
Thanks!
Yes.What i want to do is RTSP streams as users  join meeting.
The video is H264,the audio is AAC.
Chunbo_H_Intel1
Great. Thanks. The information would help us improve!
