Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
on a null object reference
Justin__Justin
初学者
973 次查看
Environment:
- Ver: ICS 4.1.1
- ICS-Conferece
- Do not use mixing.
java.lang.NullPointerException: Attempt to invoke virtual method 'void com.intel.webrtc.a.n.a(java.lang.String, org.json.JSONObject, io.socket.client.a)' on a null object reference
    at com.intel.webrtc.a.b$22.run(ConferenceClient.java:559)
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
    at java.lang.Thread.run(Thread.java:764)
0 项奖励
3 回复数
YanbinZ_Intel
员工
973 次查看
Could you please provide detail test environment included test devices OS info etc and reproduce steps .
Yanbin
0 项奖励
Hr__Z
新分销商 I
973 次查看
the android example has bug, You should process the conference obj very carefully, there's an order between their dispose func.
0 项奖励
YanbinZ_Intel
员工
973 次查看
Could you please try 4.2 version ?  We can't reproduce this issue .
Could you please provide detail iOS devices info and Android device info ?
Yanbin
0 项奖励
回复
