Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
rabbitMQ server error
Saito__Business
Hi . I am beginner to use Intel OWT. using Release  Ver4.3.
When I start MCU server, logs/webrtc-agent.stdout gives following error messages.
please someone help to fix this error. I can not access rabbitMQ server.
2020-04-24 15:48:55.912  - INFO: AmqpClient - Connection to rabbitMQ server error { Error: read ECONNRESET
    at TCP.onread (net.js:622:25) errno: 'ECONNRESET', code: 'ECONNRESET', syscall: 'read' }
Chandramouli_P
Hello Saito,
Please check your port, and firewall. If everything goes well, stop all agents in MCU first and then restart your server.
Thank you.
Chandramouli.
Saito__Business
Thanks Chandramouli.
 I build up my local PC, therefore I am not using firewall.  If you do not mind, please advice how I can check port.all of them build up on my local PC.
I try to follow instruction manual except certification part, I am afraid this error comes from certification configuration.
BRs.
