ConfSampleMFC.exe!__report_gsfailure(unsigned __int64 stack_cookie) 行 220 C
ConfSampleMFC.exe!rtc::GetStringFromJsonObject(const Json::Value & in, const std::basic_string<char,std::char_traits<char>,std::allocator<char> > & k, std::basic_string<char,std::char_traits<char>,std::allocator<char> > * out) 行 274 C++
ConfSampleMFC.exe!owt::conference::ConferenceSocketSignalingChannel::Connect(const std::basic_string<char,std::char_traits<char>,std::allocator<char> > & token, std::function<void (std::shared_ptr<sio::message>)> on_success, std::function<void (std::unique_ptr<owt::base::Exception,std::default_delete<owt::base::Exception> >)> on_failure) 行 130 C++
ConfSampleMFC.exe!owt::conference::ConferenceClient::Join(const std::basic_string<char,std::char_traits<char>,std::allocator<char> > & token, std::function<void (std::shared_ptr<owt::conference::ConferenceInfo>)> on_success, std::function<void (std::unique_ptr<owt::base::Exception,std::default_delete<owt::base::Exception> >)> on_failure) 行 330 C++
这是我的报错 有人知道为什么吗
- Tags:
- HTML5
- JavaScript*
Could you please provide more information to help us to verify the problem ?
Detail reproduce steps. Detail environment e.g hardware/software .
Yanbin
