Hello
I'm trying to install the MCU server version 2.1.1
I get an error on the console when I try to start the server with this command bin/start-all.sh. Before I did carefully all the steps suggested in the MCU server UserGuide.
the log file woogeen-nuve.stdout shows the following information:
events.js:72
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE
at errnoException (net.js:904:11)
at Server._listen2 (net.js:1042:14)
at listen (net.js:1064:10)
at Server.listen (net.js:1138:5)
at EventEmitter.app.listen (/home/Documents/Release-v2.1.1/node_modules/express/lib/application.js:595:24)
at Object.<anonymous> (/home/Documents/Release-v2.1.1/nuve/nuveAPI/nuve.js:1:2669)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
the log file woogeen-mcu.stdout shows the following information:
2015-05-22 11:23:43.582 - INFO: RPC - Exchange rpcExchange is open
2015-05-22 11:23:43.584 - INFO: RPC - ClientQueue amq.gen-QRqzQyMbxcJvNxiYTiFcTR is open
2015-05-22 11:23:48.629 - INFO: ErizoController - Failed to join nuve network.
I appreciate your help.Thanks
- Tags:
- HTML5
- JavaScript*
use /restart-all.sh. You have already started one instance that why it is telling you its EADDRINUSE. If not, then try a different port in config for nuve.
If yon can't stop it by restart-all.sh, use ps -ef | grep -i node and kill -9 <processId> which represents nuve, erizo and other related ones.
Hi Dennis,
The best practice that Farrukh shared should help you fix your issue. What's more, EADDRINUSE tries to tell us this is the error of address-in-use...
Hi
The problem was solved by restarting the server.
OK. Cool. Hard reboot is also a good approach.
