Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
webrtc 3.3 , Login error
BRUCE_L_
Hello, i am using version 3.3, centos 7.2
Follow the steps to install the server, start the server,
In version 53 of the Google browser enter https://192.168.1.186:3004
The following error occurred:
ERROR: server connection failed: Participant Ff3IvYdDREhb5Hl4AAAA join session 58a397f889d0146a63476ec6 failed
Test a lot of times or so, then re-install the server, or the above errors,
Ask for help, thanks!
BRUCE_L_
Did anyone encounter this problem? Help me, thank you.
Lei_Z_Intel1
Have you started the MCU correctly without error log? Can you zip your log folder and paste here or send us through webrtc_support@intel.com?
BRUCE_L_
I sent it to your mailbox, please check it out
BRUCE_L_
Lei_Z_Intel1
Video work node start fail. Can you check whether you have './videoMixer_sw/build/Release/videoMixer-sw' fold and a xxx.node file under it. Also the user you run start_all.sh has proper execution permission on it.
2017-05-18 03:04:36.496  - ERROR: VideoNode - { [Error: Cannot find module './videoMixer_sw/build/Release/videoMixer-sw'] code: 'MODULE_NOT_FOUND' }
    at Function.Module._resolveFilename (module.js:337:15)
    at Function.Module._load (module.js:287:25)
    at module.exports (woogeen/video/index.js:88:33)
    at _third_party_main.js:116:56
    at /home/sct/3.3/Release-v3.3/video_agent/amqp_client.js:1:5275
    at /home/sct/3.3/Release-v3.3/video_agent/amqp_client.js:1:1272
    at Queue._onMethod (/home/sct/3.3/Release-v3.3/video_agent/node_modules/amqp/lib/queue.js:466:9)
    at Queue.Channel._onChannelMethod (/home/sct/3.3/Release-v3.3/video_agent/node_modules/amqp/lib/channel.js:85:12)
    at Connection._onMethod (/home/sct/3.3/Release-v3.3/video_agent/node_modules/amqp/lib/connection.js:454:28)
    at AMQPParser.self.parser.onMethod (/home/sct/3.3/Release-v3.3/video_agent/node_modules/amqp/lib/connection.js:136:12)
BRUCE_L_
I have this file.
This problem is solved, I found that the first implementation. / Init-all - deps, and then implement. /start-all.sh, the above problems will not occur,
But there was a new problem...
Console
ERROR: create LocalStream failed: Object {code: 1104, msg: "Not all device requests are satisfied."}
As shown below:
This is a log file  550846
I used the 3.1 version of the time, the use of the same camera, did not appear this problem, what is the reason for this error? Thank you!
Lei_Z_Intel1
Seems your local device not ready, check the error flag in upper corner of Chrome.
BRUCE_L_
I was not a microphone, I modified script2.js in the
Woogeen.LocalStream.create ({
               video: {
                 device: 'camera',
                 resolution: myResolution
               audio: false
It's up.
But I found 3.1 before the version, even if there is no microphone, audio is true, it will not have this problem ah, which is why?
All in all, thank you for your help.
Lei_Z_Intel1
Yes, we changed the local media creation behavior after v3.1. After changing we will exactly follow customer specified parameters. If not match, report error.
Mansi_J_
Mansi_J_
I am having the same issue . Please help me out.
Thank you!!
Mansi_J_
Mansi_J_
Mansi_J_
node: ./lib/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by node)
node: ./lib/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by node)
Lei_Z_Intel1
@Mansi, make sure your Ubuntu version is LTS14.04 64bit with its default c++ library.
Mansi_J_
@Lei I am using ubuntu LTS16.04.
Is there any problem with that:(
Reply asap.
Lei_Z_Intel1
We only tested with 14.04, 16.04 should not work especially with different version C++ library.
Mansi_J_
Is there any way to import that particular library??
Mansi_J_
Screenshot from 2017-06-06 13-09-14.pngI was able to import the library but for createToken i am getting status code 401 unauthorisedScreenshot from 2017-06-05 12-27-09.pngI was able to import the required library but now I am getting the error 503(SERVICE UNAVAILABLE).
Please reply asap.
Naresh_R_1
@Mansi,
It works with Ubuntu 16.04 too, please use server edition instead of desktop version and follow the installation steps it should be  not a problem
Naresh
