Intel® Compute Stick
Discussions Regarding Intel® Compute Sticks and Cards
547 Discussions
1st gen windows 10 need drivers
DG2
Hey all i have been trying to install windows 10 pro onto my compute stick since i was unabled to do a reset (it said something about it failed to reset) and my restore partition is not there any longer.
When i get to the part where i need to choose my hard drive to install too it shows up as blank with the message that is in the attached image here. As you can see in the cmd box it shows the hard drive but for some reason it doesnt know its there in the setup program...
Could someone zip up their drivers and send them my way? The ones i downloaded on intels website do not seem to work when i inject them into the .wim and choose them manually on that screen.
Hello TDavidG,
My apologies for the inconvenience.
I would like to let you know that from my end the only drivers available for this model can be found here: https://downloadcenter.intel.com/product/86612/Intel-Compute-Stick-STCK1A32WFC Downloads for Intel® Compute Stick STCK1A32WFC . Since you are experiencing issues with the installation, you may also try the steps we provide for the Windows® 10 upgrade, find them here: https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000016164.html Windows® 10 Update Instructions for Intel® Compute Stick
Hopefully one of the peer viewing this thread can help you with your specif request.
Amy C.
/thread/116663 TDavidG, hope the information posted above was helpful.
Amy C.
DG2
Amy that doesnt seem to help me any. i need an image of ether windows 8.1 or 10 that already has the needed drivers on it in order to install it. No matter what drivers i used from the download page it still can not find the hard drive.
Intel provides just the generic drivers, maybe you could try getting more information with Microsoft on getting the operating system with the injected the driver; however, from my end the next step will be getting in contact with our direct support in order to check your replacement options. Find the contact information here: https://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
Amy C.
