Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
Bluetooth Lags
SSant13
Hi guys,
I just bought an Intel stick 2016 with and X5 Atom. I already updated all drivers and BIOS.
The issue that I have is the lag that I have with any bluetooth mouse or even keyboard. As soon as you open any application the lag appear.
I also tried a wireless non Bluetooth mouse and this one works flawless.
So, the bluetooth issue seems to be related when the CPU has some load.
Any of the community suffer the some thing?
Thanks in advance.
Hello Ipopox,
Thank you for contacting the Intel community.
What is the exact model of the Intel® Compute stick? I'm sorry we have two models with similar processors.
Do you have the possibility to try the Bluetooth components with another system just to isolate the issue?
Try uninstalling the Bluetooth driver and reinstall it, you can download the latest Bluetooth driver here:
https://downloadcenter.intel.com/ https://downloadcenter.intel.com/
Ivan.
SSant13
Hi Ivan,
My model is https://www.amazon.com/gp/product/B01AZC4NHS/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 (BOXSTK1AW32SC), and yes, all the BT components works prefectly in other systems.
Cheerss,
We have tested this component in our lab and we don't experience this behavior.
Did you try uninstalling and reinstalling the Bluetooth driver?
Try to pair the components again.
Also, try the following:
  • Accessing the device manager
  • Expand network adapter and right click the Bluetooth driver.
  • A screen will come up and click advance.
  • Under properties look for "Bluetooth Collaboration" and set the value to disabled.
I hope this can help.
Ivan.
LLuca5
I have the same problem using a Logitech diNovo Mini Keyboard.
I noticed that for me lag is more frequently using browser (more with Firefox, but also witn Chrome) for streaming video (Netflix and PrimeVideo) in windowed or fullscreen mode, and also running a DiskMark test on the internal disk C:. No lag with .mkv video playback using MediaPlayerClassics.
After a first time of lag I have to remove the Keyborad battery because some buttons stops working.
Windows Event Viewer reports a lot of system warnings concerning Bluetooth: HidBth - Event ID 2 - Bluetooth HID device either went out of range or became unresponsive.
I tried all the drivers, from 17.1.1532.1814 to 19.00.1621 and also 19.11.1639.649 found using Windows Update, but the problem persists. I also removed the power saving options, but with no improvements.
I can't disable "Bluetooth Collaboration" because I'm using an USB wifi adapter and there isn't this option, but I set the WiFi frequency on 5 GHz to avoid interferences with Bluetooth 2.4 GHz.
Could you please provide us with your Bluetooth keyboard and mouse models?
Do you have the latest BIOS version installed? You can download it here:
https://downloadcenter.intel.com/download/26448/BIOS-Update-SCCHTAX5-86A-?product=91065 https://downloadcenter.intel.com/download/26448/BIOS-Update-SCCHTAX5-86A-?product=91065
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000006039.html F7 BIOS Update Instructions for Intel® Compute Stick
Ivan.
LLuca5
Hi Ivan,
my Compute Stick model is BOXSTK1AW32SC and BIOS is update to the latest version 0030.
My Mouse/Keyboard is a Logitech diNovo Mini™ (http://support.logitech.com/en_us/product/dinovo-mini diNovo Mini™ - Logitech Support ) that I used with no problems on the previous media center.
On the Compute Stick at first I tried to use the Logitech USB receiver (and SetPoint driver released by Logitech), but I experienced lag problems; so I connected the device using the Compute Stick Bluetooth, but lag persists.
We have tested this unit with Bluetooth and it works fine not specifically with this device you have because Intel has not validated it but it should work, at this point we can help you with a warranty replacement for the unit. I have sent you a private message.
Ivan.
昌森田
Hallow
I also have a similar problem. my system is following
compute stick STK1AW32SC atom z8330(new one) date of manufacture: 13 sep 2016
Bluetooth mouse iBuffalo BSMBB21S
Bluetooth mouse elecom M-BT7BR
When I activate Bluetooth mouse it seems to move fine.
But after I play solitaire game about a half an hour
the mouse pointer does not move smooth. (lag, slow, fast )
My Bluetooth mouse works fine at other machines (including Compute Stick STCK1A32WFC)
I already updated BIOS and all drivers.
I contacted Intel Customer Support, and got a replacement (date of manufacture: sep 2016).
But the situation is the same.
Thank you tektek for sharing this information with us.
Would you please provide us with your Bluetooth mouse model to further investigate this issue?
Also, I will really appreciate if you could attach the DxDiag and the Msinfo32 to better assist you.
Best wishes,
Ivan.
昌森田
Hello Ivan
My Bluetooth mouse models are following
iBuffalo (maker) BSMBB21S
elecom (maker) M-BT7BR
Both makers are japanese and the products are made in china.
I run DxDiag and it says ^No problems found^.
Anyway I will send you the results by email.
Thank you
Thank you for the information, please allow me to further investigate this issue.
Ivan.
昌森田
Hi Ivan,
I tried to send the results of DxDiag and the Msinfo32 by email
but I couldn't do that. Maybe the address was wrong.
If you need those results, please teach me the way to do it.
Thank you for your investigation.
Ronny_G_Intel
Community Manager
Hello everyone,
I have been testing several mouse types Bluetooth and USB with no luck and have been also checking on other customers reporting the same issue.
I found out a couple of customers describing the same issue and reporting that it was the TV/Display causing the mouse lagging.
Would it be possible for someone on this community thread to test using the BOXSTK1AW32SC on a plain PC monitor and share back the results?
Ronny G
昌森田
Hello Ronny G,
I use it on a plain PC monitor.
Is the CPU of your computer atom z8330(not z8300)?
Thank you
Just for testing purposes can you please check what happens if you try to use the BT portion but disconnected of any WIFI network available? WIFI 7265 card shares the same antenna to TX/RX BT and WIFI. Also another test is connecting the wireless to 5 GHz instead 2.4 GHz. BT works at 2.4 only.
Also is it possible for you to provide us with the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility ISSU log and the BT driver that you have installed. SSU does not capture the BT information.
Download Intel® System Support Utility
  1. Download the utility
  2. Run the exe and select 'Scan'
  3. Save and include as an attachment in the Intel Community Forum
I would recommend the following as well:
Get the new drivers just posted for the https://downloadcenter.intel.com/download/26528/Intel-PROSet-Wireless-Software-and-Drivers-for-Windo... Intel® Wireless-AC 7265 (version 19.30 for WIFI and BT) and perform a full clean uninstalling of the WIFI and the BT driver making sure that the "delete the driver software from this device " option is selected and keep removing the driver to the point that the WIFI adapter is shown as unknown device when looking in device manager and from there reinstall the software again. https://downloadcenter.intel.com/download/26510/Intel-Wireless-Bluetooth-Software-for-Windows-10 BT software needs to be installed first and then the WIFI in that specific order.
Ivan.
昌森田
Hi Ivan,
This is my the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility ISSU log.
I run windows10 in Japanese mode, so this file contains some Japanese words.
BT driver is BT_19.30.1649_32_Win10 (ver. 19.30.1645.851).
Now I am connecting the wireless to 5 GHz.
Still my Bluetooth mouse pointer delays.
This delay is not constant.
Suddenly the pointer moves slower and then moves faster.
Thank you for the information and for trying that for us, I very much appreciate it.
Ivan.
Would you please provide me with the monitor/TV model that your are using with the Intel® Compute stick?
I will really appreciate if you can post this information.
Ivan.
昌森田
Hi Ivan,
My monitor is Mitsubishi RDT271WV.
Ronny_G_Intel
Community Manager
Hi tektek,
I would recommend that you contact Intel Customer Support via phone to check on any possible workaround or options we have available.
Here is our http://www.intel.com/content/www/us/en/support/contact-support.html# @4 Contact Support information. Please make reference to case number: 2195335.
Ronny G
