Intel® Compute Stick
Discussions Regarding Intel® Compute Sticks and Cards
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
548 Discussions
Cmake error faced with OpenVINO Toolkit for Windows 10 when running demo_squeezenet_download_convert_run.bat
ShowChak
My system configuration:
a. Visual Studio 16 2019 Community Edition
b. cmake 3.16.4 (with path variables SET)
c. Anaconda Python 3.7.3 (all path variables SET)
I am following the steps outlined in "Install Intel® Distribution of OpenVINO™ toolkit for Windows* 10"
I run into following cmake error when running demo_squeezenet_download_convert_run.bat
###############|| Generate VS solution for Inference Engine samples using cmake ||###############
Waiting for 2 seconds, press a key to continue ...
Creating Visual Studio 16 2019 x64 files in C:\Users\xxxxx\Documents\Intel\OpenVINO\inference_engine_samples_build...
'cmake' is not recognized as an internal or external command,
operable program or batch file.
Error
Any help is greatly appreciated.
AndrewG_Intel
Hello SChak32
Regarding your inquiry about the error when using Intel® OpenVINO™ toolkit, we would like to inform you that the proper channel of support for this type of inquiries is throught our Intel Developer Zone.
In this case, we kindly recommend you to address this inquiry to this department by submitting a support ticket via Online Service Center. To submit a case for our products. See How to Create a Support Request at the Online Service Center.
You may also refer to the main support page on Intel Developer Zone for additionnal information and to connect with other developers and technical experts through its public forum.
Note: You may need to register before accesing thsese websites.
Registration Intel® Developer Zone
https://software.intel.com/registration/
Andrew G.
ShowChak
Thank you for clarifying, Andrew. I have already registered for accessing the website.
BTW, I was able to solve the problem by reinstalling cmake and Visual Studio 2019 community edition and then by setting the environment variables corrects. I did not have all the packages in Visual Studio installed when I got the error.
AndrewG_Intel
Hello SChak32
Thank you for your response.
We are glad to know you were able to solve the problem and thank you for the feedback provided. Hopefully, it may help other community members experiencing the same issue. We will proceed to close this inquiry.
Andrew G.
