I purchased the Intel compute stick (BOXSTCK1A32WFC) approximately a year ago. I had difficulty getting it set up, but eventually it began to work after advice from the Intel technical support. Based on the advice from technical support I set Windows not to automatically update. It has worked fine for several months, then it has set idle and not used for the past six months. This week I tried to use it and it is freezing when video playback from Amazon Prime running movies, it seems to run 8-12 minutes or so, and then it bricks up and the only way to get any response is to completely unplug all cables and reboot. I am reluctant to upgrade the windows version as it appears from discussions on the support community that upgrading cause all kinds of problems. Can you help me figure out a way to run an Amazon prime video without interruption?
- Tags:
- Intel® Makers
Hello stillnesssage,
Thank you for contacting the Intel community.
At this point, I suggest you to report this issue to Amazon and see if the Intel® Compute stick is able to work with this unit.
Honestly, I have not seen this issue with this Intel® Compute stick, do you have the latest graphics driver with the https://downloadcenter.intel.com/download/25647/Intel-HD-Graphics-Driver-for-Intel-Compute-Stick-STC... Intel® Compute stick.
Update the BIOS; you can download the latest BIOS version here:
https://downloadcenter.intel.com/download/26447/BIOS-Update-FCBYT10H-86A-?product=86612 https://downloadcenter.intel.com/download/26447/BIOS-Update-FCBYT10H-86A-?product=86612
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000006039.html Please see F7 BIOS Update Instructions for Intel® Compute Stick
Make sure your internet connection is working correctly; maybe you can try resetting the router if it is possible.
Ivan.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
