Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
531 Discussions
How to get cpu temperature in ubuntu ? Fan control ?
AKara13
I'm running ICS headless via SSH. (the latest firmware solved headless problem, no issues there)
I am experiencing some shutdowns, which I suspect might be temperature related.
Is there a command line way to get CPU temperature ?
Also, is there a way to control the fan ? I never witnessed it kicking on (I didn't do anything CPU intensive though), if possible I would like to make it always on.
Community Manager
Hello coze,
In regard to your concern, after an extensive research I was able to find this link:
http://askubuntu.com/questions/15832/how-do-i-get-the-cpu-temperature http://askubuntu.com/questions/15832/how-do-i-get-the-cpu-temperature
With some commands and helpful information that you can use with Ubuntu.
If you would like to know additional information related to Ubuntu, I recommend you the following website:
https://www.ubuntu.com/support/community-support Ubuntu Community Support
I am looking forward to hearing from you.
Angie
Community Manager
Hello coze,
Angie
