Intel® Compute Stick
Discussions Regarding Intel® Compute Sticks and Cards
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
548 Discussions
How to install fresh Windows 10 PRO
ŁBąk
I have stick STCK1A32WFCR with pre installed Windows 8 and now i want to install Windows 10 Enterprise (i have legal key etc).
But installer cant see hard Drive, and i cant find any working drivers that i can put during instalation.
Do u have any solution ?
AlHill
Go here and create a USB stick: https://www.microsoft.com/en-us/software-download/windows10
You will need a USB stick with at least 8gb.
Next, use a USB hub.
Plug your mouse/keyboard into the hub
Plug the usb stick into the hub
Boot the usb stick
Choose custom install, and delete any and all partitions you have on your 32gb emmc
Install Windows 10.
After the FIRST restart, but before the actual reboot, remove the USB stick.
Personally, I would create a 32-bit install usb stick. With on 2gb memory, it makes little sense to do a 64-bit install of windows 10.
Doc
ŁBąk
Im think u not read all what I write. I know how to install windows from usb stick, my problem is that installer did not see my internal memory so I cant​ see emmc memory.... And I can't install the system.
AlHill
I am not sure what is wrong. W10 enterprise is supported:
https://www.intel.com/content/www/us/en/support/articles/000005899/mini-pcs/intel-compute-sticks.html
One of the Intel support engineers will be able to assist you.
Doc
