I spend the last night to recovery my intel compute stick after upgrade to win 10
the upgrade to win 10 work fine but after finish all is gone,the ICS booting ok but after that is lock down in the configuration task
As we know Intel no offers the image to restore and back to life the stick
I found the solution and i hope the admin no delete this tread
What you need?
1 hub usb with minimun 2 ports
1 usb flash drive minim 8 GB with Fat32
1 keyboard with usb cable
please download the image recovery
http://mab.to/66CmT8hCN http://mab.to/66CmT8hCN
after download it*s finish unzip *Ics_win8.1_recovery.zip* file to the root of an usb flash drive
put the flash drive and keyboard in the usb hub and power up the ICS and press F10
in the boot menu select the EFI USB DEVICE{YOUR NAME USB FLASH} and hit enter
confirm with Y when ask {2 or 3 times}
please wait {depending the speed in your usb hub and flash drive} between 15 minutes and an hour and a half
If everything went ok your Ics is back to life with windows 8 stock and with hidden partition recovery as factory
Thanks and sorry for my bad english
- Tags:
- Intel® Makers
Thanks for the helpful post.
Thank You so much. I have successfully recovered my Compute stick with your image and instructions. This is awesome. I wonder why Intel don't offer this advice as the top search result?
I used the Intel WIndows 10 upgrade instructions and now have a WIndows 10 compute stick. It works great too! 1080p Youtube video at 1920x1080 resolution with no stutter. I'm stoked.
Can you post his image since it is no longer available at his URL?
I can't see my USB flash drive when I press F10. Please help, my ICS can't boot anymore. It says it needs to be repaired.
Hello all,
msrobota, thank you for sharing this information.
Suraboi, have you tried following this method http://www.intel.com/support/motherboards/desktop/stck1a32wfc/sb/CS-035619.htm Intel® Compute Stick STCK1A32WFC — Windows* Logon Screen Appears the First Time Intel® Compute Stick Starts in order to repair it? Make sure that the USB is bootable so it can be properly recognized by the Intel® Compute Stick.
Amy.
Hi Amy, I've tried msrobota solution and it worked for mi ICS with the only exception that Windows is not activated so it doesn't let me update to Windows 10. My ICS came with Windows 10 out of the box (bought it in october) but since the last update (november), it stopped working and recovery doesn't work neither.
So the question is, is there anything I can do about it? Cause I don't have a serial number for Windows and it's not anywhere in the box.
I followed the steps just as msrobota decribe and it worked but Windows isn't activated.
Excuse my english pleace.
Thanks!
Hello all ,
Please bear in mind that the official and validated procedure is at the following link http://www.intel.com/support/motherboards/desktop/stck1a32wfc/sb/CS-035724.htm Intel® Compute Stick STCK1A32WFC — Windows® 10 Upgrade Instructions.
Matías, I have sent you a private message.
Amy.
I can't reset nor refresh my ICS to factory defaults coz my recovery partition is lost after upgrading to Windows 10. I tried msrobota resetting instruction but to no avail. I guess i need to send my ICS to intel service centre for resetting.
Another posibility for people wish try with F10 and no work
If your ICS boot and crash after when loading windows {after upgrade failure to Win 10}you can try fix and restore with F8
What you need?
1 Press F8 to enter in recovery mode
2 Click to *Use a devices*
3 Click to *UEFI:USB:{YOUR NAME FLASH DRIVE}*
Can you please post the recovery image again? I need it to try and recover my Computer Stick.
Can you please repost the image? It is no longer available at that URL. Thanks in advance.
