Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
How to set fan speed?
SMuzu
My https://downloadcenter.intel.com/product/86612/Intel-Compute-Stick-STCK1A32WFC STCK1A32WFC has the fan running at full speed all the time, even when the system is shutdown. I have to unplug the micro-usb cable every time.
I updated the bios to the latest https://downloadcenter.intel.com/downloads/eula/25191/BIOS-Update-FCBYT10H-86A-?httpDown=https://dow... FC0025.BIO. But it does not help.
Thanks a lot for any information.
IUman
Based on the description you have provided us, if the issue persists after the BIOS update, please contact us so we can replace the unit for you.
Please contact your local support group for a replacement at:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Or you can call us to our phone number 916-377-7000, we are open from 7:00AM PST to 5:00PM PST
IUman
SMuzu
Thanks a lot. I will contact newegg for the replacement then.
One more question just for curiosity.
I installed speedfan to check CPU temperature. Even with the full speed fan, CPU temperature is ~50C idle and ~60C during normal web browsing. Is it normal? Or the software is not working properly on this platform.
IUman
That temperature is fine, 50C idle and 60C during normal web browsing, basically if you are experiencing high temperature your system will shutdown automatically or you will get a pop up message saying that the system needs to turn off because the temperature is too high.
