Intel® Compute Stick
Discussions Regarding Intel® Compute Sticks and Cards
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
548 Discussions
I keep getting an error message of DATA_LENGTH for my SSD Mobilenet graph generated in the v2 environment of NCS. dimension is 300x300x3. The error I get is ' ncFifoWriteElem: 2608 input tensor length is (540000 doesn't match expected value (1080000).
OOder
I use an input dimension of 300 300 when generating the graph so I'm quite confused as to how the expected value is double of the tensor length. I have tried using various shaves to no avail. Please how do I fix this?
n_scott_pearson
Super User Retired Employee
What does this have to do with Intel's Compute Stick/Card products?
OOder
I'm using the Movidius neural compute stick.
n_scott_pearson
There is a separate forum, Intel® Neural Compute Sticks, for these types of queries (start here: https://forums.intel.com/s/topic/0TO0P000000PqZDWA0/intel-neural-compute-sticks?language=en_US).
Unfortunately, I don't have the rights necessary to move your query, so you will need to open a new query there yourself.
JAVIERJOSE_A_Intel
Hi OOder,
Thank you for reaching out.
Please answer the following questions:
  • Which version of OpenVINO™ toolkit are you using?
  • Which Operative System do you have?
  • Which command did you use to convert the model?
  • Which sample did you use to test the converted model?
  • Which input image or file did you use to test the model?
  • Are you using a custom-trained model or a pre-trained model?
  • Could you please clarify if you are using an Intel® Movidius™ Neural Compute Stick or an Intel® Neural Compute Stick 2?
Also, can you share with us the mode so we can attempt to convert? You can share it via PM in case you do not want to share it publicly.
Javier A.
A Contingent Worker at Intel
