I purchased this "Intel Compute Stick" a few months ago and was very happy with it until I made a mistake. The device was originally running Windows 8.1 and I just, nonchalantly, upgraded it to Windows 10.1 without giving it another thought! I had recently purchased a new PC and I upgraded that desktop computer to Windows 10 and everything went fine. Of course, after I realized that the Compute Stick was not working, I did some research and discovered that certain drivers had to be loaded first, before the rest of the upgrade proceeded. I am now in a real Catch 22; my main computer is now Windows 10 so I cannot make 8.1 recovery media (I tried the online tool but could not get that to work properly either).
How can I recover? I can get into the root drive ("X") and I can start in the "Safe mode" but I am still having problems getting things back to normal…
- Tags:
- Intel® Makers
Hi Jamest5303,
First I recommend you to do a recovery of the system to factory defaults:
- Remove any SD card, if installed.
- Press F8 when you see this prompt during boot: F8 to Activate Windows 8.1* Recovery Mode.
- Select Troubleshoot.
- Select Reset your PC, then select Next.
- Select just remove my files.
- Select Reset to start the restore process.
Then Update the Intel® Compute Stick BIOS; please download the latest BIOS version for this unit in the following
https://downloadcenter.intel.com/product/86612/Intel-Compute-Stick-STCK1A32WFC https://downloadcenter.intel.com/product/86612/Intel-Compute-Stick-STCK1A32WFC
Here you can find BIOS update Instructions for Intel® Compute Stick
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005961.html http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005961.html
After, you will have to proceed with the Windows® Update, I suggest you to do the recovery media step.
Check in the link below the Windows® 10 Update Instructions:
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000016164.html?wa... http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000016164.html?wa...
Windows® 10 Threshold 2 Update Guide for Intel® Compute Stick STCK1A32WFC
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000017933.html?wa... http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000017933.html?wa...
Hellen.
