Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
536 Discussions
Intel Atom® Processor Z3735F Graphics Driver
RaiRai
This is my processor:
https://ark.intel.com/content/www/us/en/ark/products/80274/intel-atom-processor-z3735f-2m-cache-up-t...
After updating my Windows Stick with Win 8 home to Win 10 home 20H2, i wasnt able to update my integrated graphics even asking a support from intel, my last resort is here.
Its said that its already discontinued. How can I upgrade the driver for this one since the the drivers from intel dont install on my system and pops an error it that it doesnt meet the requirements to install on my system?
Maria_R_Intel
Hello RaiRai,
Thank you for posting on the Intel* Community.
I found the internal case you mentioned, unfortunately, if the Intel* Drivers do not install in your system, the best is to contact the Compute Stick Manufacturer directly, those devices are highly customized and they need specific drivers to work properly, those drivers have been tested and validated to work with your specific hardware.
From the Intel side, our best recommendation is to contact the manufacturer directly, perhaps fellow community members have the knowledge to jump in and help.
Maria R.
jamie3324
i have the same problem on a lenovi miix 300 it has the exact same cpu.
have you found a solution
n_scott_pearson
Super User Retired Employee
For this processor, the last supporting Intel HD Graphics package was version 15.33.53.5161, which you can download from here: https://www.intel.com/content/www/us/en/download/18606 (note: this package installs driver version 10.18.10.5161).
This package installs just fine on my Intel Compute Stick STCK1A32WFC, which also has the Z3735F processor.
If you are having problems installing this driver, do the following:
  1. Make sure you have the driver installation executable downloaded and available on your system.
  2. Disconnect system from Internet. Unplug Ethernet cable and/or disable Wireless. Note: if using Wireless, it should be disabled in such a way that reboots can occur without it automatically re-enabling.
  3. Open the Apps & Features applet and check for an Intel Graphics Driver entry. If there is no entry, go to Step 6 below.
  4. Click on the Intel Graphics Driver entry and select Uninstall. Go through the uninstall process.
  5. Reboot the system, keeping Internet access disconnected.
  6. Open the Device Manager applet. Check the Display Adapters section for an Intel Graphics entry of some sort. If there is no entry (other than the Microsoft Basic Display Adapter entry), go to Step 9 below.
  7. Right-click on the Intel Graphics entry and select Uninstall Device. Checkmark Delete the driver software for this device and then click on the Uninstall button.
  8. Go to Step 5 above.
  9. Install the new driver package downloaded in or prior to Step 1.
  10. Reboot the system.
  11. Reconnect Internet access.
  12. Test.
Hope this helps,
AlHill
Driver 5161 installs and works fine on my stick as well.
[Waiting for Windows 12]
