When I search for drivers using the "ambiguous / confusing / non-specific" Intel search box nothing comes up unless I use the '®' char like so "Intel®"... wtf?
So I find the drivers page I need via "Google". However every single link is broken giving the error "Page Not Found". I want to update the devices bios and GPU driver.
This is the driver page not working: https://downloadcenter.intel.com/product/91065/Intel-Compute-Stick-STK1AW32SC https://downloadcenter.intel.com/product/91065/Intel-Compute-Stick-STK1AW32SC
- Tags:
- Intel® Makers
The Intel Download Center is not working currently. Try again later.
I have never had to specify the ® symbol for a search to match. This too may be an artifact of the site being down...
Ok tnx for the heads up, will try again later.
Hello zezba9000,
Thank you for contacting the Intel community.
I'm sorry that you haven't been able to download the latest driver for your Intel® Compute stick, I just try the website today and it seems to be working fine now.
Ivan U.
Yes its working now. Your auto updater tool now finds the drivers as well. Although after you update drivers that tool incorrectly checks driver versions and always reports them as out of date. FYI.
Use of the current Intel Driver Update Utility is not recommended. It is so badly broken that a from-scratch replacement is being developed. Until this is ready, it is recommended that you manually download and install the latest drivers from the Intel Download Center downloads page for your particular Compute Stick.
Thanks for the information zezba9000, and that's right it will be better to update the drivers downloading every driver from the download center.
Ivan U.
