Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
531 Discussions
Intel compute stick (STCK1A32WFC). It stopped working
JPrad4
Two weeks ago I have the Intel compute stick (STCK1A32WFC). I always took care to turn it off after use, until, again appeared to want to pin the window of my desk and more branded and never worked. I made the recovery with the F8 key but reaches 48% and then fails (sometimes less). Leave last night all night and did not exceed that percentage). How can I fix the problem?. Thank you so much
IUman
Hello Jotape,
Thank you for joining the Intel communities.
Please try the following:
Update the Intel® Compute Stick BIOS; please download the latest BIOS version for this unit at:
https://downloadcenter.intel.com/download/25506/BIOS-Update-FCBYT10H-86A- Download BIOS Update [FCBYT10H.86A]
In this case I recommend doing a BIOS recovery and you can follow the steps at:
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005902.html BIOS Recovery Instructions for Boards and Kits
After that is done reset the system to factory defaults:
  1. Remove any SD card, if installed.
  2. Press F8 when you see this prompt during boot: F8 to Activate Windows 8.1/10 Recovery Mode.
  3. Select Troubleshoot.
  4. Select Reset your PC, then select Next.
  5. Select just remove my files.
  6. Select Reset to start the restore process.
Ivan
IUman
Hello Jotape,
Ivan
JPrad4
IUman
