Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
545 Discussions
Mobile battery for stick
Hi, guys, could you please recomment a mobile power (battery) in the market for the computer stick? I bought some noted as 3A output but failed to power on the stick.
Hello leilaohu77:
In regard to your inquiry, I just wanted to let you know that the testing that Intel does on the stick is done under stock configurations using the components that came with the stick, so based on that there is not a battery brand or model that we can recommend for you to use it as mobile power (battery).
As an option you can try to use a 3000 mah or higher battery charger in order to be able to charge the stick.
Alberto
Hello leilaohu77:
I hope you were able to get the information you were looking for and if there is something else I can help you with please let me know.
Alberto
