I'm running Windows 10 on a STK1A32SC. I have a USB serial converter hooked up, and I'm tying to communicate through PuTTy. I need to identify the COM port of the device. In the device manager, the Ports & LPT are not listed. I have tried "Show hidden devices," but still nothing showed up. The device is listed under USB Controllers as "USB Serial Converter." Its location is listed as Port_# 0003.Hub_# 0001. I'm looking for a COM number (COM1, COM2,COM3, etc.). Any idea how to get the device manager to list the Port & LPT?
Tristan,
From Device Manager, open the properties for the "USB Serial Converter" device. If this driver supports the capability for emulating it as a COM port, there will be a tab that allows you to specify which COM port to emulate. You may need a different/custom driver for this particular device in order to accomplish this.
Hope this helps,
Tristan,
Hope this helps,
That did the trick. Thanks!
