Intel® Compute Stick
Discussions Regarding Intel® Compute Sticks and Cards
Power WA-20E05RUGKN HS
Millet8840
Bonjour,
Pouvez-vous m'indiquer la référence d'une alimentation USB-C pour remplacer celle de mon Intel Compute Stick.
Cordialement
AlHill
Ok, you can find a replacement here:
https://www.ebay.com/itm/APD-Type-C-USB-C-Power-Supply-WA-20E05RUGKN-NEW/264938023504?hash=item3daf896a50:g:3RwAAOSwnA9frFiQ
I am not familiar with that model Stick, but matching the model number on the power adapter should work for you.
AlHill
This is not an Intel product.  Contact the manufacturer for assistance/support.
Millet8840
C'est pourtant l'alimentation qui est fournie avec le Computer Stick quand on l'achète neuf.
AlHill
But... You do not have an Intel Compute Stick.
Even so, the Intel Compute Stick power supply does not use a USB-C connector.   It just looks like a USB-C connector.
You should still contact the manufacturer of this device for support, and verify the adapter needed for you device.
AlHill
Provide a photo of the back of your device so we can verify what you have.
Millet8840
Intel Compute Stick acheté en mars 2017
AlHill
Millet8840
On ne peut pas acheter ce produit en France
AndrewG_Intel
Hello @Millet8840
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool.
We hope that the information provided by the community has been helpful to clarify your concern.
Based on the screenshot attached, this seems to be related to an Intel® Compute Stick STK2m3W64CC. Is this correct?
We noticed that this thread has been marked as "solved". Please let us know if you have additional inquiries or if it is ok to close this inquiry now.
Andrew G.
AndrewG_Intel
Hello @Millet8840
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
