Intel® Compute Stick
Discussions Regarding Intel® Compute Sticks and Cards
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
548 Discussions
Recommended Resolution 150%?
FDano
Hi: I'm wondering if a recommended resolution of 150% is normal? It seems like I'm playing with the big blocks like this... I'm using a 65" Mitsubishi DLP TV. Thanks!
Compute Stick Model: STK1AW32SC
BIOS: 0019
Windows 10 v. 1511, 10586
EstebanA_C_Intel
Hello, InfoSysLib:
Thank you for contacting the Intel Communities again.
I am positive that this FAQ will help you to adjust the resolution in your device to get the desired/best resolution that works for you.
http://www.intel.co.uk/content/www/uk/en/support/graphics-drivers/000005502.html Intel® Graphics and Televisions Frequently Asked Questions (FAQ) for...
My recommendation would be to check the FAQ "Why can I see the center of the Windows* desktop, but not the top, bottom, and sides?" while using different resolutions available.
If you are using 150% I guess you are having issues with small lettering or the taskbar is out of the screen, that is the reason why I gave you that recommendation.
The other FAQs could also help to find a resolution that works for you, please do check them.
In case you are not able to get that resolution fixed, please provide me with a deeper explanation of what you would like to achieve so I can further assist you on this.
If you require any further information or support, feel free to contact us back.
Esteban C
