Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
531 Discussions
STK1AW32SC Unable to Sleep / Wake
DBurt2
Just received the above unit, which the v2 device very recently launched.
In Windows 10 (32-bit), there is no sleep options. Its not in the Start Menu > Power options. The "rundll32.exe powrprof.dll,SetSuspendState 0,1,0" command does not work.
Essentially, this device will be running an ongoing rolling display (VLC playlist) but I want to schedule sleep and wake scripts for overnight.
I have checked that all drivers are up to date, I have downloaded (FC0031.BIO) and tried to update the BIOS.
If I run "powercfg -a", I get the following:
C:\Windows\system32>powercfg -a
The following sleep states are not available on this system:
Standby (S1)
The system firmware does not support this standby state.
Standby (S2)
Standby (S3)
Hibernate
Hibernation has not been enabled.
Standby (S0 Low Power Idle)
Hybrid Sleep
Standby (S3) is not available.
Hibernation is not available.
Fast Startup
Is this a known issue? Is there a resolution?
Hellen_D_Intel
Hi Jingo_man, It is not a specific issue, I mean your OS is Windows® 10 with Bing, and it is not a complete Windows' package that is why you cannot see the sleep option in the start menu; and the BIOS of this Intel® Compute Stick does not have the wake option. Please try the following:· Get into the system configurationo Once there click power & sleepo Click 1- "Additional power settings"§ 2- Change Plan Settings§ 3- Change advanced power settings· There you can edit the sleep options· Apply and save
Hellen.
