Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
532 Discussions
STK2m364CC Won’t see my WiFi network but sees others
Peetyg
I’m to set up my WiFi network and it see multiple networks on my street but won’t see my home network. I have re started both my xFi modem and my wireless router but no avail. Is there any special settings in windows 10 on computer stick that need to be checked?
Thank you
n_scott_pearson
Super User Retired Employee
Do you have SSID transmission disabled? If so, you need to create an entry for accessing your network manually.
Peetyg
would I search for that on the intel stick or on my xfi home network modem
LeonWaksman
Hi @Peetyg
1. You may check this with other device with WiFi connection. For example your mobile phone. Can you connect to your local WiFi? Can you see the identification (SSID)? If not enable Wifi in your router.
2. If you can see your SSID, enable WiFi in Windows Settings in your Compute Stick: Network & Internet > WiFi set to ON and then click on Show available networks.
Leon
