Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
532 Discussions
The sound stopped working on my STK2M3W64CC compute stick.
JPatt3
I tried the "Trouble Shooting" thing in Windows 10 and the uninstall driver process to no avail.
So what I would like to try is to physically delete the driver files and replace them with a newly downloaded files if you think that would help.
AlHill
What version of Windows 10 are you running? 1809? Lower?
Doc
JPatt3
It is running Version 1809 OS Build 10.0.17763.
n_scott_pearson
Super User Retired Employee
And what is the version number for the Intel HD Graphics driver package that you have installed? Again, need package version, not driver version.
JPatt3
I got the report from the Intel Driver & Support Assistant and I do not see that listed anywhere.
Could you tell me where to find it?
n_scott_pearson
Right-click on Windows Start button and select Apps and Features. Look for entry for Intel Graphics Driver package. Selecting this entry should list the version number.
JPatt3
​In the Apps and Features, all I have listed is the Intel Graphics Driver, no package or HD graphics listing. The driver is the same as the listing in the Device Manager, 25.20.100.6519 dated 3/5/19. So, is that a problem?
n_scott_pearson
No, it is not a problem, per se, but,
  1. There was a new BIOS, version 59, released March 5th. If you haven't already, you should install this update.
  2. There is a newer graphics driver available that you could download and try (here: https://downloadcenter.intel.com/download/28731/Intel-Graphics-Windows-10-DCH-Drivers?product=88354).
Hope this helps,
JPatt3
OK, thank you, I will get the new BIOS and look into installing that new graphics driver.
As to the sound problem, it just started working again. I had not figured out anything to do to fix it, it just started working again on its own. It stopped working after a Win10 update and I think just the restarting, shutting down and starting up again finally let it complete the update. The sound driver is M701d-A3/A3R High Definition Audio Driver.
Thank you for your help.
JPatt3
My sound problem just went away, it started working again on its own. I had not figured out anything to do to fix it, it just started working again on its own. It stopped working after a Win10 update and I think just the restarting, shutting down and starting up again finally let it complete the update. The sound driver is M701d-A3/A3R High Definition Audio Driver Version 25.20.100.6519 dated 3/5/19.
