Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
WPA2 Enterprise
Hi
Has anyone managed to connect to a WPA2-Enterprise wifi network?
Cert is installed, GPO pushes the network config which is confirmed with "netsh wlan show profiles". But, the network isn't visible.
We have 2 other SSID's on the same controller - one is open, the other is WPA2-Personal. I am able to connect to these fine. Other devices can see the Enterprise network just fine.
Does anyone know if this is a limitation of the driver or the RTL8723BS hardware? This thing is fairly useless in a domain environment if I have to connect it to Ethernet.
Cheers.
Tags (1)
Highlighted
Hello Hoops,
Let's wait for other user comments, but I'll check internally to see if this configuration has been tested.
Highlighted
I'm guessing no feedback from your team? I suspect it is hardware/driver as I can't see the Enterprise network on Windows or Ubuntu.
