Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
WPA2 Enterprise
DH4
Hi
Has anyone managed to connect to a WPA2-Enterprise wifi network?
Cert is installed, GPO pushes the network config which is confirmed with "netsh wlan show profiles". But, the network isn't visible.
We have 2 other SSID's on the same controller - one is open, the other is WPA2-Personal. I am able to connect to these fine. Other devices can see the Enterprise network just fine.
Does anyone know if this is a limitation of the driver or the RTL8723BS hardware? This thing is fairly useless in a domain environment if I have to connect it to Ethernet.
Cheers.
Hans_B_Intel
Hello Hoops,
Let's wait for other user comments, but I'll check internally to see if this configuration has been tested.
DH4
I'm guessing no feedback from your team? I suspect it is hardware/driver as I can't see the Enterprise network on Windows or Ubuntu.
