Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
531 Discussions
Where can I find the drivers for STK1AW32SC Windows 10 x64, especilly for the device ACPI\VEN_8086&DEV_22A8?
RThun
AlHill
All drivers for your stick can be found here: http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/intel-compute-sti... Intel® Compute Stick STK1AW32SC
Doc
RThun
For Windows 10 x64 or Windows 8.1 x64 i cannot find any drivers?
EstebanA_C_Intel
Hello, RobertThunell:
Please find the supported OS in this link: http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005899.html Intel® Compute Stick Supported Operating Systems
Kindly refer to the section "Other operating systems" (below the chart).
If you require any further information or support, feel free to contact us back.
Esteban C
RThun
Thanks, couldn't find that.
EstebanA_C_Intel
No problem RobertThunell
If you require any further information or support, feel free to contact the Intel Communities again.
Esteban C
Mitchell_R_Intel
SC Compute Stick only has drivers for 32 bit Windows 10 since that is what comes with the unit. There is no driver support for 64bit as of now. Maybe in the future?
EstebanA_C_Intel
Hello, MrMitch:
Thank you for the inquiry.
I cannot assure if drivers for 64-bit drivers are going to be release or not.
32-bit based OS is the one Intel® considered is the best regarding performance for the unit, so far, you could check every once in a while in the download center to look for driver releases (https://downloadcenter.intel.com/ Drivers & Software)
Esteban C
YIwah
I installed the drivers for STK1A32SC with driver signature enforcement disabled, and the number of "unknown device" has been reduced to 4 now.
Is there any clue what these 4 indicate?
I believe STK1AW32SC and STK1A32SC are identical in terms of hardware.
EstebanA_C_Intel
Hello, MINORISUKE:
There is an option.
It would be to check the HW ID's of those devices.
Here how you can check that:
1. Access device manager and find the unknown devices.
2. Right click and properties.
3. Go to "Details" tab
4. Change Property From Device Description to Hardware ID's
5. Copy those codes and google them
Regularly, when you do this, you are referred to a website related to an specific component of the computer, which can better advise you on the drivers to look for.
Hope this helps, any additional questions please let us know.
Esteban C
