Intel® Compute Stick
Support for Intel® Compute Sticks and Cards
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
536 Discussions
can laptop hdmi port usd for monitor for intel stick
sJosh4
can laptop hdmi port be usd as moniter for intel stick
CCool
I can say with 99% certainty, no, you cannot use your laptop's HDMI port as a monitor for the Intel Compute Stick. It normally doesn't work that way (that HDMI is only for Output, not for Input).
Best I think you could do would be TeamViewer, SplashTop, VNC but those all require a network connection (Wi-Fi or USB Ethernet Adapter).
AYerb
I am not an expert but I would think that that will not work as the HDMI on your laptop would be to send data not receive it.
Kevin_M_Intel
Hello nanachimpu,
The HDMI output Port of a laptop is configured in a different way than a input port of a monitor. So I regret to say that this configuration you would like to do is not going to work.
Kevin M
