Have Not found a remedy for this issue when plugging into the hdmi port on my tv.
any thoughts?
- Tags:
- Intel® Makers
Hello btrom56,
Could you please be more specific about this issue? Please let us know the hardware that you're using.
Amy.
A mode not supported on the Samasung Tv indicates that the resolution being inputed is not correct for the hdmi port. I tried changing the resolution on the stick but it didn't resolve the issue. Can this be a compatibility problem with this earlier dlp TV ?
Yes, it might be possible that you're facing a compatible issue with this T.V.
Have you tried using a newer T.V?
Regards.
