Hello I'm using intel compute stick on wind10 with openvino.
I was runing one of demo for object detection and, I noticed that I can not run twice the demo. the first start and works fine, but when I run the second one I got this error (can not init MYRIAD device : NC_ERROR) . I have to keep only one app, otherwise will not run. Is that normal, we cannot init myriad multiple times ? What if we want to use differents video sources?
thanks in advance
Hi momo,
This behaviour might be expected since the Intel® Neural Compute Stick 2 is being used by your first demo. As such, you may use two Intel® Neural Compute Stick 2 for two different demos.
However, if you run two similar demos because of different video sources, you can try with this Multi-Channel Object Detection Yolov3 C++ Demo which allows you to run a demo with various different inputs.
Peh
Hi momo,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Peh
