Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
подойдет ли 4Gb PC3-10600 1333MHz DDR3 DIMM CL9 Kingston HX313C9FB/4 HyperX FURY Black Series для DESKTOP BOARDS DH55PJ
ЕИван
будет ли она работать в этой материнке?
EstebanA_C_Intel
Hello, Wodalaz:
After using the translate option in here I was able to understand you would like to know if this RAM would work with your system.
Here you can find a list of specs regarding RAM compatibility with your motherboard.
• Two 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM)
sockets
• Support for DDR3 1333 MHz and DDR3 1066 MHz DIMMs
• Support for 1 Gb and 2 Gb memory technology
• Support for up to 8 GB of system memory with two DIMMs using
• Support for non-ECC memory
If the RAM modules are within those specs, they should work with your board.
Information found here: https://downloadmirror.intel.com/18913/eng/DH55PJ_ProductGuide01_English.pdf https://downloadmirror.intel.com/18913/eng/DH55PJ_ProductGuide01_English.pdf
Esteban C
ЕИван
Спасибо!
но вот еще 1 вопрос!
Support for 1 Gb and 2 Gb memory technology???? (Support 4 gb memory ?)
Support for up to 8 GB of system memory with two DIMMs using ------2+2=4 Gb memory (two DIMMs using )
можно ли поставить 8gb ?
почему написано что поддерживает до 8 gb ?
а наделе максимум 4 gb?
n_scott_pearson
Super User Retired Employee
Note: 2GB = 2 gigabytes; 2Gb = 2 gigabits.
When they mention 2Gb, they are referring to the capacity of the individual ICs that are needed on the DIMMs. You need 2Gb ICs in order to build a DIMM providing a total of 4GB of memory. You need two 4GB DIMMs to reach a total of 8GB.
I hope I have explained this in a way that translates well...
ЕИван
Спасибо! Все понятно=)
EstebanA_C_Intel
Hello, Wodalaz:
Thank you Scott for the additional information provided regarding this.
Esteban C
