Intel® Desktop Boards
Peer-to-peer support only
11477 Discussions
安装INF驱动始终提示需要管理员权限,即使使用管理员登陆
EZhou2
系统版本Win0 1903
INF驱动版本:10.1.17968.8131_Public,10.1.17711.8088_Public
​使用Mainboard:ASROCK Z390 Phantom Gaming 6
blow is the install log
[1E08:2564][2019-06-23T13:06:18]i200: Plan begin, 3 packages, action: Install
[1E08:2564][2019-06-23T13:06:18]i000: ** MBA ** Planning related bundle for uninstall. BundleId: '{ffddf9dd-c47f-453a-92f5-ac6c98af8b5b}' State: 'None' Result: 'None'
[1E08:2564][2019-06-23T13:06:18]i202: Planned bundle: {ffddf9dd-c47f-453a-92f5-ac6c98af8b5b}, ba requested state: Absent over default: None
[1E08:2564][2019-06-23T13:06:18]w321: Skipping dependency registration on package with no dependency providers: DotNet45
[1E08:2564][2019-06-23T13:06:18]i052: Condition 'NOT VersionNT64' evaluates to false.
[1E08:2564][2019-06-23T13:06:18]i204: Plan 3 msi features for package: SetupChipsetx86.msi
[1E08:2564][2019-06-23T13:06:18]i203: Planned feature: NullDriverFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[1E08:2564][2019-06-23T13:06:18]i203: Planned feature: PackageVersionFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[1E08:2564][2019-06-23T13:06:18]i203: Planned feature: LicenseAgreementFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[1E08:2564][2019-06-23T13:06:18]i052: Condition 'VersionNT64' evaluates to true.
[1E08:2564][2019-06-23T13:06:18]i204: Plan 3 msi features for package: SetupChipsetx64.msi
[1E08:2564][2019-06-23T13:06:18]i000: Setting string variable 'WixBundleRollbackLog_SetupChipsetx64.msi' to value 'C:\Users\rense\AppData\Local\Temp\Intel\Logs\Chipset_20190623130603_000_SetupChipsetx64.msi_rollback...
[1E08:2564][2019-06-23T13:06:18]i000: Setting string variable 'WixBundleLog_SetupChipsetx64.msi' to value 'C:\Users\rense\AppData\Local\Temp\Intel\Logs\Chipset_20190623130603_000_SetupChipsetx64.msi.log'
[1E08:2564][2019-06-23T13:06:18]i201: Planned package: DotNet45, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1E08:2564][2019-06-23T13:06:18]i201: Planned package: SetupChipsetx86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1E08:2564][2019-06-23T13:06:18]i201: Planned package: SetupChipsetx64.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[1E08:2564][2019-06-23T13:06:18]i207: Planned related bundle: {ffddf9dd-c47f-453a-92f5-ac6c98af8b5b}, type: Upgrade, default requested: None, ba requested: Absent, execute: Uninstall, rollback: Install, dependency: None
[1E08:2564][2019-06-23T13:06:18]i299: Plan complete, result: 0x0
[1E08:2294][2019-06-23T13:06:18]i000: Setting string variable 'IIF_MSI_SWITCHES' to value ''
[1E08:2294][2019-06-23T13:06:18]i000: ** MBA ** Getting window handle.
[1E08:2294][2019-06-23T13:06:18]i000: ** MBA ** Calling Engine.Apply(). Window handle: 525964
[1E08:2564][2019-06-23T13:06:18]i300: Apply begin
[13D4:07A0][2019-06-23T13:06:18]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{c30dc778-ac13-4f91-9045-fea2331ceb2e}, options: 0x4, disable resume: No
[13D4:07A0][2019-06-23T13:06:18]i320: Registering bundle dependency provider: {c30dc778-ac13-4f91-9045-fea2331ceb2e}, version: 10.1.17711.8088
[13D4:07A0][2019-06-23T13:06:18]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{c30dc778-ac13-4f91-9045-fea2331ceb2e}, resume: Active, restart initiated: No, disable resume: No
[13D4:07A0][2019-06-23T13:06:18]e000: Error 0x80070005: Failed to write run key value.
[13D4:07A0][2019-06-23T13:06:18]e000: Error 0x80070005: Failed to update resume mode.
[13D4:07A0][2019-06-23T13:06:18]e000: Error 0x80070005: Failed to begin registration session.
[1E08:2564][2019-06-23T13:06:18]e000: Error 0x80070005: Failed to begin registration session in per-machine process.
[1E08:2564][2019-06-23T13:06:18]e000: Error 0x80070005: Failed to register bundle.
[1E08:2564][2019-06-23T13:06:18]i000: ** MBA ** Apply complete. Status: '-2147024891' Restart: 'None' Result: 'None'
[1E08:2564][2019-06-23T13:06:18]i399: Apply complete, result: 0x80070005, restart: None, ba requested restart: No
[1E08:2294][2019-06-23T13:06:18]e000: ** MBA ** 0x00000005 您必须拥有管理员权限才可完成此操作。
[1E08:2294][2019-06-23T13:06:26]i000: ** MBA ** ResultCode=5
[1E08:2564][2019-06-23T13:06:26]i500: Shutting down, exit code: 0x5
[1E08:2564][2019-06-23T13:06:26]i410: Variable: CHIPSET_PRODUCT_VERSION = 10.1.17711.8088
[1E08:2564][2019-06-23T13:06:26]i410: Variable: DotNet40Client = 1
[1E08:2564][2019-06-23T13:06:26]i410: Variable: DotNet40Full = 1
[1E08:2564][2019-06-23T13:06:26]i410: Variable: DotNet45 = 528040
[1E08:2564][2019-06-23T13:06:26]i410: Variable: IIF_ExtractionMapping_SetupChipsetx64.msi = ;NullDrivers.cab;VersionNT64
[1E08:2564][2019-06-23T13:06:26]i410: Variable: IIF_ExtractionMapping_SetupChipsetx86.msi = ;NullDrivers.cab;NOT VersionNT64
[1E08:2564][2019-06-23T13:06:26]i410: Variable: IIF_MSI_SWITCHES =
[1E08:2564][2019-06-23T13:06:26]i410: Variable: INSTALLER_BUILD_VERSION = 3.1
[1E08:2564][2019-06-23T13:06:26]i410: Variable: NTProductType = 1
[1E08:2564][2019-06-23T13:06:26]i410: Variable: VersionNT = 10.0.0.0
[1E08:2564][2019-06-23T13:06:26]i410: Variable: VersionNT64 = 10.0.0.0
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleAction = 4
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleElevated = 1
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleLog = C:\Users\rense\AppData\Local\Temp\Intel\Logs\Chipset_20190623130603.log
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleLog_SetupChipsetx64.msi = C:\Users\rense\AppData\Local\Temp\Intel\Logs\Chipset_20190623130603_000_SetupChipsetx64.msi.log
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleManufacturer = Intel(R) Corporation
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleName = 英特尔® 芯片组设备软件
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleOriginalSource = D:\My Temp\Z390 Phantom Gaming 6\DVD\Drivers\INF\Intel\(v10.1.17711.8088_Public)\SetupChipset.exe
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleOriginalSourceFolder = D:\My Temp\Z390 Phantom Gaming 6\DVD\Drivers\INF\Intel\(v10.1.17711.8088_Public)\
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleProviderKey = {c30dc778-ac13-4f91-9045-fea2331ceb2e}
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleRollbackLog_SetupChipsetx64.msi = C:\Users\rense\AppData\Local\Temp\Intel\Logs\Chipset_20190623130603_000_SetupChipsetx64.msi_rollback...
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleTag =
[1E08:2564][2019-06-23T13:06:26]i410: Variable: WixBundleVersion = 10.1.17711.8088
[1E08:2564][2019-06-23T13:06:26]i007: Exit code: 0x5, restarting: No
AlHill
This forum is for intel desktop boards.
Does the inf install?
Doc
EZhou2
o,sorry
I just want to know how to install inf
cloud you please foward to the correct forum
AlHill
Well, there is no forum for asrock boards.
Windows 10 1903 should have all the information you need. Why do you think you need to install the INF? And, from where did you get the INF?
Doc
EZhou2
I have install other intel dirvers is ok, ex. the RapidStorage , intel vga, Intel ME & intel network dirvers
just the inf, can't install and popup the error msg is ‘No administrator privileges’
and the dirver file at this intel web site downloaded. so i think maybe this dirver need some pecial methods
AlHill
When you right-click on the INF, do you have the option to install?
Doc
EZhou2
yes, i have, and the same pop-up prompt even when using administrator login
AlHill
Just as a test, create a new profile with administrator privileges. Then, log in with the new profile, and try to install the INF.
It is 01:52 in the morning where I am, and I am going to get some sleep now.
Doc
EZhou2
Thank you very much for your kind help.
i will test this ​methods
EZhou2
