Hello
I'm curently builded a brand new desktop PC. I have trouble with a WD drive.
It takes almost 1 hour until a 1GB is written to the drive. The transfer rate falls below 4MBytes /s (in windows). The SMART feature doesn't report any trouble. When the transfer rate drops, it seems that the drive seek the secors where to write.(Moves the heads back and forth)
At first I thought that can be a driver issue but is not be ,because I have another two drives (500 GB each) on the sane SATA Host and I don't have this issue. I tried on different SATA ports (6 and 3 Gb).
I tried also to lowlevel format the drive with their utility (DLDIAG) in dos and windows, but the time needed was to long (about 80 hrs) to complete. I put the drive into another PC (on Intel DQ45CB board ) and the format process takes only 2 hrs.(2 hrs is normal)
The SATA interface settings in the BIOS is set to AHCI and NCQ is enabled.
My configuration is:
Mainboard: Intel® Desktop Board DX79SI
CPU: Intel Core i7 3930K
RAM: 32GB Geil Veloce (Quad Channel)
HDD: 1 x Intel 240 GB SSD (520 Series)
2 x Seagate ST3500320
1 x WD20EARX-00PASSB0 (firmware 51.0AB51)
OS: Windows 7 SP1 64 bit
Windows SysInfo
Item Value
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Manufacturer INTEL_
System Model DX79SI__
System Type x64-based PC
Processor Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz, 3201 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date Intel Corp. SIX7910J.86A.0553.2012.1027.1042, 10/27/2012
SMBIOS Version 2.6
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
Time Zone GTB Standard Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 28.9 GB
Total Virtual Memory 63.8 GB
Available Virtual Memory 60.4 GB
Page File Space 31.9 GB
Page File C:\pagefile.sys
I downgraded the BIOS to the prevous version (SIX7910J.86A.0537),but didn't change nothing. Can be a hardware issue or just a driver or BIOS bug. The drive works well on Intel DQ45CB board.
Any other ideea will be helpful. Thank you
Which motherboard SATA data port is the drive attached to?
The issue is only with this WD drive.
[Disks]
Item Value
Description Disk drive
Manufacturer (Standard disk drives)
Model ATA INTEL SSDSC2CW24 SCSI Disk Device
Bytes/Sector 512
Media Loaded Yes
Media Type Fixed hard disk
Partitions 2
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 0
SCSI Target ID 0
Sectors/Track 19
Size 223.57 GB (240,055,287,808 bytes)
Total Cylinders 110,164
Total Sectors 468,857,984
Total Tracks 24,676,736
Tracks/Cylinder 224
Partition Disk # 0, Partition # 0
Partition Size 100.00 MB (104,857,600 bytes)
Partition Starting Offset 1,048,576 bytes
Partition Disk # 0, Partition # 1
Partition Size 223.47 GB (239,949,840,384 bytes)
Partition Starting Offset 105,906,176 bytes
Model ATA ST3500320AS SCSI Disk Device
Bytes/Sector 512
Media Loaded Yes
Partitions 1
SCSI Bus 3
SCSI Logical Unit 0
SCSI Port 0
SCSI Target ID 0
Sectors/Track 63
Size 465.76 GB (500,105,249,280 bytes)
Total Cylinders 60,801
Total Sectors 976,768,065
Total Tracks 15,504,255
Tracks/Cylinder 255
Partition Disk # 2, Partition # 0
Partition Size 465.76 GB (500,105,740,288 bytes)
Bytes/Sector 512
Media Loaded Yes
Partitions 2
SCSI Bus 5
SCSI Logical Unit 0
SCSI Port 0
SCSI Target ID 0
Sectors/Track 19
Total Cylinders 229,504
Total Sectors 976,769,024
Total Tracks 51,408,896
Tracks/Cylinder 224
Partition Disk # 3, Partition # 0
Partition Disk # 3, Partition # 1
Partition Size 465.66 GB (499,999,834,112 bytes)
Model ATA WDC WD20EARX-00P SCSI Disk Device
Bytes/Sector 512
Media Loaded Yes
Partitions 0
SCSI Bus 2
SCSI Logical Unit 0
SCSI Port 0
SCSI Target ID 0
Sectors/Track 63
Size 1.82 TB (2,000,396,321,280 bytes)
Total Cylinders 243,201
Total Sectors 3,907,024,065
Total Tracks 62,016,255
Tracks/Cylinder 255
[SCSI]
Item Value
Name Intel(R) C600 Series Chipset SATA AHCI Controller
Manufacturer Intel Corporation
Status OK
PNP Device ID PCI\VEN_8086&DEV_1D02&SUBSYS_49538086&REV_05\3&21436425&0&FA
I/O Port 0x00004068-0x0000406F
I/O Port 0x00004074-0x00004077
I/O Port 0x00004060-0x00004067
I/O Port 0x00004070-0x00004073
I/O Port 0x00004020-0x0000403F
Memory Address 0xEB527000-0xEB5277FF
IRQ Channel IRQ 4294967285
Driver c:\windows\system32\drivers\iastora.sys (3.5.1.1008, 563.96 KB (577,496 bytes), 12/15/2012 12:30 PM)
Now is connected to 3Gbps. I tried in all SATA ports. I also exhanged the SATA cables, but it's the same issue.
SATA PORT 0: INTEL SSDSC2CW24
SATA PORT 1: -
SATA PORT 2: WDC WD20EARX-00P
SATA PORT 3: SEAGATE ST3500320AS
SATA PORT 4: TSS ATAPI CD/DVD
SATA PORT 5: SEAGATE ST3500320AS
SATA MODE AHCI . No RAID array is defined.
I put the WD Green Hard Drive into external rack (connected via USB)and I don't have anymore the issue.
It seems that, Intel motherboard DX79SI doesn't like the WD Green drives, which parks his heads in every 8 sec.
It's very sad, that intel didn't come ,with a BIOS update related to this issue. I didn't wanted to send back the board for RMA ,but next time I will choose another manufacturer.
