Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
3 beep code
FHasa1
Hey guys I have an intel dz77re-75k mother board and ballistix tactical memory and I keep getting the 3 beep code I have checked online for what I could do and it has not helped also this problem used to only occurs occasionally but recently it has started to occur more often Can anyone help?
Jose_H_Intel1
Hi faizan156, did you check if the memory is compatible with your system?
http://www.intel.com/support/motherboards/desktop/dz77re-75k/sb/CS-033457.htm Intel® Desktop Board DZ77RE-75K — System Memory
Are you using BIOS default settings?
You may test a single memory stick in order to see if a memory stick is defective.
It may be possible to upgrade the system BIOS if the system boots with a single memory stick.
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS Update Instructions
