Hey guys I have an intel dz77re-75k mother board and ballistix tactical memory and I keep getting the 3 beep code I have checked online for what I could do and it has not helped also this problem used to only occurs occasionally but recently it has started to occur more often Can anyone help?
Hi faizan156, did you check if the memory is compatible with your system?
http://www.intel.com/support/motherboards/desktop/dz77re-75k/sb/CS-033457.htm Intel® Desktop Board DZ77RE-75K — System Memory
Are you using BIOS default settings?
You may test a single memory stick in order to see if a memory stick is defective.
It may be possible to upgrade the system BIOS if the system boots with a single memory stick.
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS Update Instructions
