Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
3 beep error code after changing memory parameters
jjohn81
DH87MC - upgraded memory from 8 to 32GB, began working well after adjusting the memory params on the Performance page.
I then decided to optimize (?) it by adjusting the 4 timing params to match the memory specs. Default had been 9 9 9 24, which I changed to 10 11 10 30. Saved and restarted with F10, Yes. Worked okay, but I noticed that the timing values were back to default. Set them to memory specs again, restarted, got the 3-beep 'no memory' error.
So far I've been unable to clear the CMOS (or perhaps doing so did not return it to working defaults?) using the remove-the-battery-and-wait method. (The PSU has an AC switch, so I didn't actually unplug it, though. Trying that as I write, no hope though.
Other than shopping for a replacement motherboard, is there anything else to do? Although there was no obvious reason the memory was damaged, I did the normal drills of trying the original memory in various slots. There's nothing external plugged in except for SATA drives, a (Displayport) monitor, and an ethernet connector (which LED shows activity while the bios is beeping at me).
ppara5
Valued Contributor I
10-11-10-30 is a strange timing specification. I've never seen RAM where the first three numbers weren't the same. Are you sure it isn't 10-10-10-X?
jjohn81
I don't pretend to understand the rules, but Patriot PV332G186C0QKBL says 10-11-10-30.
In any case, I would be happy if the bios were to reset it to 9-9-9-24, as I sit here waiting for Newegg to email me that I can pick up my replacement motherboard.
By way of a grouse, I have to comment that it's a shame that Intel gave up on desktop boards - I used to depend on that product line for robust reliability - but it's slightly more shameful that they didn't stop selling them a year or so sooner, before this miserable lot was foisted on the public.
jjohn81
After leaving the battery out with the PSU unplugged for a couple of hours, I cleared CMOS. The system always gives 3 beeps (repeatedly). I can get to the startup menu and thence to setup by holding the power button through the four-beep sequence, although I may have to try a couple of times.
After verifying/setting CMOS data I restarted; still 3 beeps, but the special power-on procedure still gets me to that special menu, and CMOS.
The memory works fine in a different motherboard and provides appropriate XMP data, and that board automatically sets memory timing correctly.
The Intel board doesn't give me a opportunity to select an XMP profile - choices are manual or auto, and auto does not choose the correct timing for the given memory module.
ppara5
I am not an Intel employee so this is not a definitive answer, but in my experience DH boards only offered the manual/auto choice while DZ boards offered the XMP selection. I have a DH67BL board which accepted my changing the RAM settings from 9-9-9-24 to 7-7-7-24, with a noticeable increase in speed.
And I agree with you regarding Intel boards no longer being made. Intel has made a few strange decisions, with giving up on the smartphone market being one of them.
Community Manager
Hello, All:
Thank you for your feedback.
The supported cas latency for this motherboard is 9, any other latency will be overclocking, and from our it is no supported.
Amy.
