Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
3 monitors wanted
dyno
i got i7 3770 processor & intel hd 4000 graphics. got on intel website & it said it supports 3 monitors. i can only get 2 to display. at monitor setup, it shows 3 monitors ( where you can switch them around) , and can get all monitors to work from there connections , but cant get them on at same time. could someone help me out? thanks
n_scott_pearson
Super User Retired Employee
What motherboard/system do you have? How is the processor graphics exposed? HDMI? DisplayPort (DP)? VGA? DVI?
dyno
thanks for replying. its a work computer. left work for today. do i have to look at actual motherboard to see what it is, or is it in system properties? its got blue vga port, and i think 4 display outputs. will look tomorrow to make sure. i know i had one monitor in vga port, 2 in digital output ports with hdmi converters. the monitor plugged into vga port stayed on. could get one or other monitor to work both plugged into separate display ports , but not both at same time.
dyno
baseboard , dell
0gy6y8 version a01
2 display ports, 1 vga port
n_scott_pearson
Dell, hhmmm, not a good sign. Your only option is to try using a MST Hub device or MST-based daisy-chaining to connect multiple monitors to a single DisplayPort output. As was reported, one person tried this but it didn't work for them. The results may be different for you - or not, I cannot tell.
If you want link to MST Hub device you could try, I can provide one...
