Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
3 short bits at power on
JAnge3
Cuando prendo la PC tengo 3 bits cortos una pausa y otros 3 bits cortos otra pausa y otros 3 bits cortos, la PC se inicia perfectamente y trabaja sin ningun inconveniente. Realize el test de memoria de INTEL y no detecta problemas, tambien hice el test de motherboard de INTEL y tampoco detecta problema. Resetee las placas de memoria y conectores en el motherboard sin resultado.
Alguien tiene alguna sugerencia de porque sucede esto. Muchas gracias
n_scott_pearson
Super User Retired Employee
No, this should only happen if the BIOS is unable to properly configure the DRAM and get it running...
JAnge3
Any suggestion how I can solved this situation ?
n_scott_pearson
Replacing the DRAM would be a good first test. First, try running with only one DIMM installed. Try this DIMM in every DIMM slot. Switch to the next DIMM. If they all seem to be working alone and there are 4 DIMMs, try installing a pair in the blue slots and then again in the black slots. It you have problems anywhere, replace with a totally different set of DIMMs (try to borrow some, not purchase, in case it is something else).
JAnge3
Ok thank you I will tried your suggestion. Regards
JAnge3
Problem was solved after I made your suggestions. Tanks a lot. Ragards
n_scott_pearson
No problem; that's why I'm here.
