Intel® Desktop Boards
Peer-to-peer support only
11432 Discussions
3TB Raid 1 Support
NGeok
Current Configuration:-
Windows 7 64-bit SP1
Legacy BIOS
SSD Boot Drive (C:)
Raid 1 array using 2TB HDD (D:)
I would like to rebuild my Raid 1 array using 3TB HDD.
Is this supported by RST without having to use UEFI?
Advise appreciated.
Thank you.
Allan_J_Intel1
Thanks for joining the Chipset community.
There is a limitation of 2TB per volume, this means you need UEFI enable to be able to rebuild the array.
http://www.intel.com/support/chipsets/imsm/sb/cs-022304.htm Intel® Rapid Storage Technology (Intel® RST) — RAID Features by Chipset/Controller Hub
Allan.
