I have Windows 7 Ultimate x64 running without any problems for about a month on a system based on DH87MC with 8GB ram, Samsung 840 pro, and WD 1TB Green.
Yesterday, I installed a 180GB 525 ssd on the msata port planning to move the boot partition from the Samsung ssd to the 525. Intel Data Migration failed to install complaining that no Intel SSD was present.
After powering down the system and re-seating the 525, I entered the bios to verify that the 525 was displayed. Data Migration again failed to install. I rebooted the system. This time the bios showed the msata was "not installed". I powered down the system again, disconnected the Samsung ssd and the WD hard drive, leaving only the DH87MC, 8GB ram, the 525, and optical drive.
After verifying that the 525 is showed on the bios, I tried to install the OS, Windows 7 Ultimate x64, directly on the 525. The installation failed at "Copying files 0%" and "Expanding files 1%" with an error message stating that the files are missing. I redid the whole power down thing and retry the installation with a different installation dvd. This time Windows 7 installation showed that some partitions have already been created. I deleted the partitions and retry the installation. It again failed at the same point.
After several tries with similar dismal results, I gave up. I removed the 525, reconnected the Samsung 840 pro and WD hard drive, and the system booted up without any problems. Actually I am typing this message on the same computer that had trouble recognizing the 525 ssd. I thought of getting the ssd exchanged but after searching online and learning that other users have reported similar issues with DH87MC and the 525 ssd, I decided to post here for Intel's advice.
Edited 10/28/2013 2147
Added system info:
DH87MC
i5-4570S
Geil Evo Leggera DDR3 4GB x 2
Cooler Master eXtreme Power Plus 550W
Samsung 840 pro 256GB
WD Caviar Green 1TB
- Tags:
- SSD
John - I'm running into the same issue. Please see my post here:
/thread/45811 https://communities.intel.com/thread/45811
-ChrisG
Updated - November 7, 2013:
Tried the 525 ssd with an msata to sata3 adapter on the same board yesterday. OS installation completed without a hitch. Definitely there is a problem with the msata port on the DH87MC boards.
JohnTee, we already reported this issue to the engineering team for further investigation. Any update will be posted on the following thread
What did intel engineering team discovered in last 14 months?
Sylvia helps here, Diego there, after year and half solution is nowhere. Sad to see intel moved R&D somewhere into the Bhutan borderland and scrapped support completely.
