Intel® Desktop Boards
Peer-to-peer support only
11430 Discussions
82579V Gigabit Network Connection appear as 82579LM on Windows 8.1 x64
AFons1
We have problems Installing Windows 8 x64, the Network driver have issues almost on evey boot
st4
New Contributor III
Hi UIA-IT,
Thank you for the post. Please help provide further info to check on this:
1) What is the model of your system?
2) What is the driver version ?
3) Where did you download the driver? from system vendor or Intel website?
https://downloadcenter.intel.com/download/23071/Network-Adapter-Driver-for-Windows-8-1- Intel® Download Center
rgds,
wb
AFons1
Good Morning, the mother card is dh61ww, the driver version is 4/15/2014, 19.1, is under the Intel Download Center and the operating system is Windows 8.1 Enterprise, the problem we have is that the same network card sometimes grabs two different driver models when grasping Intel 82579V sails and works well when sailing grabs 825791LM not give scan for hardware changes after that changes if you navigate to and 82579V
st4
New Contributor III
Hi UITA-IT,
Thank you for the info.further checking I will forward your concern to our desktop board support to better assist on this. Thanks.
rgds
wb
AFons1
Hi wb_Intel,
Thanks for your time ,
We will be wainting for an answer.
Rgds!
