Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
A good combination
JSleg
I'm considering to buy an Intel DZ87KLT-75K mainboard with an Intel 4770 without K and DDR3 PC2400 16 Gb Quadkit from Kingston KHX24C11X3K4/16X.
Will this be a good and working combination?
Kind regards,
John
Kevin_M_Intel
Hello jslegers,
Based on the description you provided, the combination between the motherboard DZ87KLT-75K and the i7-4770 processor will definitely work.
You can check the processor compatibility list for this motherboard at the following link:
http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DZ87KLT-75K http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DZ87KLT-75K
It is also important to mention that the processor i7-4770 is capable to run with a memory speed up to 1600MHz and the memory you have is 2400MHz. However, by default this memory will run at 1333MHz. This means that if you use the memory at 1600 MHz or 1333MHz the processor will work just fine but if you use it higher, it will cause internal problems in the processor.
Kevin_M_Intel
Hello jslegers,
JSleg
Hello Kevin,
Thank you for your reply.
With kind regards,
John
