Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Active or Passive DP adapter for DZ77BH-55K
I am about to purchase several DZ77BH-55K motherboards and plan to use two DVI monitors with them. This board has a HDMI and Displayport output so I wanted to know if the following configuration would work:
Display Port > DVI (Using a passive adapter)
HDMI > DVI
Both monitors will be set to a resolution of 1920x1080.
I found this Intel FAQ that say yes, this configuration should work with Passive adapters (albeit with a 3 montior config):
http://www.intel.com/support/graphics/intelhdgraphics4000_2500/sb/CS-033714.htm http://www.intel.com/support/graphics/intelhdgraphics4000_2500/sb/CS-033714.htm
Question: Is passive dongle supported in 3-display configurations?
Answer:
Yes. Passive dongles are supported if the system manufacturer programmed the BIOS to support dual-mode interoperability (DisplayPort > HDMI, DisplayPort > DVI, DisplayPort > VGA).
Note See display combinations for valid passive dongle configurations based on the connected display.
So does this board have dual mode interoperability enabled in the BIOS?
Ali
Community Manager
Hello aliatgb,
I understand that you are inquiring if the Intel(R) Desktop Board DZ77BH-55K will have dual mode interoperability enabled in the BIOS.
In regards to your inquire, it will support the dual mode interoperability and it is enabled by default.
Regards.
PV
