Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
After BIOS upgrade the SPDIF is not working, DQ77KB
APetk
after I did a BIOS upgrade on a new board DQ77KB I noticed that the SPDIF via the 3.5mm jack is not working any more.
I've found a similar discussion the it only works with BIOS 0048 so if Intel reply on that it would be great as I don't want to downgrade the BIOS and need the S/PDIF to work.
Alex
Kevin_M_Intel
Hi alex1234,
I am sorry to hear you are having problems but let me help you.
I would like to verify more information about your system. Can you please post your dxdiag report here? Please make sure all drivers are updated to the latest (Graphics, Management Engine, BIOS, etc)
Also, can you please provide the steps you are taking to reproduce the problem or let us know what software are you using?
APetk
Hi Kevin,
I've already update all to latest version.
It's very simple to see the problem, as there is not red glow on the 3.5mm port.
here is the dsdiag:
System Information
Time of this report: 2/12/2014, 00:15:46
Machine name: PC
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_gdr.131030-1505)
Language: English (Regional Setting: English)
System Manufacturer: INTEL_
System Model: DQ77KB__
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5-3470S CPU @ 2.90GHz (4 CPUs), ~2.9GHz
Memory: 16384MB RAM
Available OS Memory: 15304MB RAM
Page File: 1440MB used, 16166MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0152&SUBSYS_20368086&REV_09
Display Memory: 1792 MB
Dedicated Memory: 992 MB
Shared Memory: 800 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Dell S2740L(Digital)
Monitor Model: DELL S2740L
Monitor Id: DELA08D
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3379 (English)
Driver Version: 10.18.10.3379
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Not Supported by WiFi driver
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 12/21/2013 10:02:46, 10591744 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4212-11CF-05EE-3C00B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0152
SubSys ID: 0x20368086
Revision ID: 0x0009
Driver Strong Name: oem15.inf:5f63e534c477ad23:iIVBD_w81:10.18.10.3379:pci\ven_8086&dev_0152
Rank Of Driver: 00DA2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess...
Kevin_M_Intel
alex1234,
Checking the DQ77KB board specifications, it does not have a header for the S/PDIF so I assume you are using this jack to convert the signal.
It is important to mention that the usage of the adapters/convertors is not supported and there may appear inconsistencies when using it.
I am going to send the feedback to the proper department for future considerations but in the meantime, if the previous BIOS version was working fine, I recommend you going back to the previous version while we check what the problem could be.
MMISS55
to support what alex says,
I could get it working only when downgraded to bios update 48, no luck with 49, 51, 52, 53
(you simply don't get that realtek digital output)
DBar-
I think it is a disgrace that any BIOS after 0048 disables the TOSLINK.
cstov1
Well, I don't know if this will help, but I have a DH87MC motherboard and I too had a similar problem. My computer case has a plug-in on the front for a headphones and microphone. There is a header on my board for these options. I was going through to update all the things available from Intel including the BIOS and the Realtek audio drivers. After I was finished I noticed I no longer had access to these plug-ins on the front. Mainly the headphones is what I was concerned with. So I backdated the BIOS till I was at the original and there was no change. So then I started with the Realtek audio driver updates and did the same thing. It only took me uninstalling the first update, which was the latest available, to realize that it was the audio driver update that was causing me to lose the headphone jack option in the sounds dialog box. Once I removed the Realtek update, Windows 7 64 Bit reverted back to the generic driver and I got the headphone jack back again in sound. So then I re updated the BIOS to the latest version and I still had the headphone option available. So my conclusion is that it is the Realtek audio driver that doesn't support the front plug-in for the headphones.
DBar-
Well, apparently there are many ways to frustrate users. In my (actually OUR, I am not alone) case, the "Realtek Digital Output" appears (see last picture in previous post by ALIELO, above) only after you install the Realtek driver. I disappears when the BIOS is upgraded beyond 0048 and reappears when downgraded to 0048, without reinstallation of the driver. I can always see front and back analog outputs.
Kevin_M_Intel
I am really sorry for the inconvenience. I will pass all this feedback to the corresponding department.
Kevin M
