Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Ajuda Placa Mãe Não da Video Com VGA
aEspi3
placa mãe da 1 bipe curto quando coloco a placa de vídeo GTX 1050TI ela da imagem mas não dai da tela da bios e quando retiro a GTX ela liga normalmente ja testei com outras placas e funcionou normal e a GTX também funcionou em outros desktops
Minha Configuração
Placa mãe - Intel DB75EN
Processador - Intel Core I5 3330
8 Gb De Memoria RAM trabalhando em dual channel
fonte 500w 80plus
1 HD 1TB
Sera que a bios esta desatualizada? se atualizar resolve?
motherboard of 1 short beep when I put the video card GTX 1050TI it of the image but it does not give of the screen of the bios and when I retire the GTX it connects normally already I tested with other plate and it worked normal and the GTX also worked in other desktops
My Settings
Motherboard - Intel DB75EN
Processor - Intel Core I5 3330
8 GB RAM memory working on dual channel
500w 80plus power supply
1 HD 1TB
Is the bios outdated? if updating resolves?
n_scott_pearson
Super User Retired Employee
Please answer these questions:
  1. What is complete identification string for the graphics card? What manufacturer? What version?
  2. What version of the BIOS do you have installed on the DB75EN board? Hint: the latest available version is BIOS 46 (ENB7510H.86A.0046.2013.0704.1354).
  3. Do you have UEFI enabled in the BIOS? If not, please try with it enabled.
