Dear People!
I recently assembled with Core i7 4770K processor - DZ87KLT-75K Motherboard,
the problem is when I shut down my computer it's 1, automatically turning on
2, when it's become sleep mode after that I must restart the computer otherwise it won't work properly (the mouse will stuck even the sound also will get disturbance)
Dennis,
Make sure that you have the latest BIOS and the latest drivers for all of your hardware installed. You can get the latest BIOS and motherboard drivers here: https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine... Download Center. For all add-in cards (graphics, etc.), make sure the latest drivers available from their manufacturers are installed as well.
...Scott
Scott I have checked all the hardware and the BIOS everything is up to date
the problem not solved
DennisRuban, would you please test your system out of the chassis with minimum configuration like processor, motherboard, power supply and 1 memory stick on DIMM # 1?
Please remove any additional accessory such as video card, wireless card, hard drive etc.
I am using the same system configuration, latest BIOS and Windows 8.1 and I am not getting that behavior.
I done all above sylvia
which SMPS your using
also I want to know the watt of the SMPS
I am using 600Watt Cooler Master Thunder 600 Watts PSU
I'm using the Cooler Master Silent Pro M 1000W power supply. http://www.coolermaster-usa.com/product.php?product_id=2949 Silent Pro M 1000W - Cooler Master
